oil gauge erratic...still
oil gauge was doing this for a little while. It has stopped but it will occur every once in a while randomly. What might this mean? I do have a oil leak and Im working on tracking that down once i get all the oil spray cleaned off the underside of the engine.
http://www.youtube.com/watch?v=cyF7cKIomjs&list=PL7E7C3A8930C6D9FE&feature=mh_lolz
Black 1984 944
2003 Land Rover Freelander SE3
Old 03-15-2012, 10:27 PM
Proprietoristicly Refined
John_AZ's Avatar
Moving on from the brakes to the oil pressure guage....
You could have a faulty oil pressure sender. It is attached to the oil cooler.
First clean the contacts on the sender. Be careful-, the posts are hollow and brittle. Very easy to break off. Locally a sender can cost $50 or more.
Check the wire to the sender. It lays over the top of the WP water pump and the sheilding gets brittle and cracks. It may be shorting on the engine block.
Replacing the sender may solve the problem.
Another possibility would be the "O" rings on the OPRV oil pressure relive valve. If they are hard and brittle it would cause a fluctuation on the dash guage. Order the "O" rings and replace. No alignment tool is needed if you do not move the OPRV housing. Get the aluminum crush washers for the OPRV and the drain nut at the same time.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-16-2012, 06:12 AM
Mine did that when one of the wires at the sender was loose.
Old 03-16-2012, 11:29 AM
@ John_AZ I'm sure the order of repairs doesn't make much sense, but at least now with a operational clutch and brakes I can atleast limp her to a mechanic if need be.
Black 1984 944
Old 03-16-2012, 11:47 AM
John_AZ's Avatar
Be careful what you whisper about your car.
It may seen unusual but "bad news happens in threes" I have been told.
GL
John
Old 03-16-2012, 12:00 PM
With my car, if its only 3 thing,I will be elated!
Black 1984 944
Old 03-16-2012, 01:02 PM
thanks for the replies. good info to start with! When I get something figured out I will let you guys know!
Black 1984 944
Old 03-16-2012, 04:26 PM
bigbirdh2's Avatar
What does this mean? - YouTube
Mine did that one day after I put in a new Alpine CD/MP3-Deck I pulled out the center console again and checked the wires going in the back and that 2 wire plug-in was just vibrating on the tongs and plug connector making my gauge act just like that.
This is with it working now with me turning one the car and off again to show you how fast that needle can jump. Hope this helps.
I posted a video response on Youtube but it says I have to wait for you to okay it!
! All metal craftsman/ Hand metal shaping/Tig-Mig, All metals-Etc, restorer/Porsche, Street , custom, race, original bodies and cars of history!
Old 03-16-2012, 05:25 PM
bigbirdh2's Avatar
MOV00790.AVI - YouTube
Old 03-16-2012, 07:13 PM
@bigbirdh2 I will check that out as well!
Black 1984 944
Old 03-17-2012, 12:21 PM
Old 03-17-2012, 05:41 PM
