fan only works on "4"
subject says all... cabin fan just stopped on the way home from the grocery store last night... I assume it's a resistor pack, but where do I find it?
nate (I think this car wants to be perpetually broken)
1988 944... and a bunch of other cars
On my S2 it's under the bonnet by the fan.It has a wireharness with a flat plug on the end that goes into it and it has 2 phillips screws holding it in.
Cleaned mine up with vinegar and it worked ok.
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
That Guy
Mine used to do the same thing. The contacts on the resistor pack are exposed to the elements and need to be cleaned. The fan will only work on four because no resistance is used. Mine usually crapped out on really hot days.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Like other posters suggested: clean the contacts on the resistors. They are actually thermostats because the ceramic resistors get hot. Speed 4 has no resistance and gets 12V.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
thanks guys, I'll give it a look see. hopefully you all are right and it just needs a cleaning. It's not hot today, but I suspect it will be later in the week.
nate
