-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   unknown connector????where to plug it!!! (http://forums.pelicanparts.com/showthread.php?t=357944)
dorsche 07-19-2007 07:35 AM
Hello
I'm little lost here , few days ago i swapped the motor in my 924 and ( new donor came from 87 944) and next to the firewall ,on the back of the engine head is unused connector .Its a 3 lead round connector attached to the rear engine lift point. Its similar in look to the o2 sensor plug . I don't see where it should be plug too. I'm little lost , i don't have diagrams neither manual .. did some search but not much luck . Thank you in advanced .
Dan
944 Ecology 07-19-2007 07:59 AM
Its a connector for the TDC sensor that was used back in the 80s with a shop oscilloscope. Ignore it (unless you have a large shop oscilloscope and need a trigger signal.)
dorsche 07-19-2007 08:18 AM
thank you much sir. Not planning to analyze it with oscilloscope:) hehe . Thank you for help
Dan
p.s.lots of useful info on your site
