-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   In the **** in Spain (http://forums.pelicanparts.com/showthread.php?t=363599)
GraemeB 08-24-2007 09:49 AM
Tried to bleed air from the coolant on my 924S by loosening the 12 mm bolt just before the upper radiator hose....the head sheared (it was ready to go) and coolant everywhere.
Fortunately 100 yards from garage so all OK.
The question?....what size is the replacement bolt?.....12 mm by ?
No peace with a Porsche.............Saludos..............GraemeB
aribop 08-24-2007 05:38 PM
It is a 12mm head but the bolt is 8mm x 8, thread pitch is 1.0. The bolt is hollow and has a hole in the side of the threads near the head.
Buena suerte! Si no lo puedes encontrar, responde y te envio uno.
toolboy62 08-24-2007 06:57 PM
I believe what you want is a banjo bolt, but it's too dark/hot/lazy right now for me to go look.
nate
GraemeB 08-25-2007 04:07 AM
Hola Aribop,
ˇGracias por su gran respuesta!
Mi amigo que está en Escocia me enviará la pieza de recambio.
Mientras voy a buscar para un tornillo provisional.
ˇGracias otra vez!..........un saludo cordial............................GraemeB
John_AZ 08-25-2007 09:52 AM
GraemeB, German please this is a Porsche Forum.
Maybe...
Wat mut, dat mut (What must be done, must be done)
Mein lieber schieber (Exclamation of astonishment or apperciation)
Besser als in der hose geschiessen (Better than making poopsy in your trousers)
Dank
John_AZ
Bohemia/Austrian mix
aribop 08-25-2007 09:58 AM
GraemeB,
Está bien. Si en el futuro necesitas algo, me puedes mandar un PM. Yo tengo bastantes piezas de recambio y tambien las pongo en Ebay.
Ciao,
Adalbert
