944S engine type and serial ?
i just moved to Belgium, and in the process of importing and registring my 944S
they asked me where the engine number is located now i found the type number, exhaust side, near firewall and that says 44 JD http://www.944forum.com/forum/imageh...58aa9d934a.jpg which is a number i can't find anywhere in the workshop manual ( lists 944S as M44.44 ) the engine serial itself, should be located around the oil filler pipe, near the clutch and next to the speed sensors , towards the passenger side but it's impossible to see anything because the inlet parts block the view http://www.944forum.com/forum/imageh...58bae88bad.jpg this is what i see, but it doesn't really look like a regular 944 engine serial anybody has any ideas about the M44 JD number?? or about how to best see the engine number on a 944S ?? |
bump
anyone? got a better pic of that serial location looks like R "V like Logo" OOT v or perhaps R Vlogo DOT v definately not a regular serial http://forums.pelicanparts.com/uploa...1188562284.jpg |
engine number
Hi I'm new here.
did you find the engine number? pls because I have the same problem. |
See Porsche 944 Engine Parts. Hope this helps.
| All times are GMT -8. The time now is 10:55 AM. |
