Catalytic Converter
Hey all, been lurking on the forum for awhile now.... gotten alot of useful info. Question: anybody have diffculty installing aftermarket direct fit CC's? Anybody recommend a particular brand? I assume the aftermarket piece will fit into the sleeve (manifold side) that connects to the exhaust pipe. Is this gonna need to be welded?
87' 924S |
aftermarket cat replacement
Hi, I used an aftermarket 50 dollar cat and it will fit with pipe cutting but didn't seal up entirely on the engine side so I had to pick up a stainless band clamp from napa and clamed it down. It has been a few years now with no problems. You may want to have yours welded if not you may have to go my route. I did pass emissions testing with flying colors twice since.
Cars & Coffee Killer
What is this "catalytic converter" device that you all speak of?
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Good question..I sure wouldnt know!
'86 Porsche 944, Guards Red Nancy is currently [going in for the final 'once over' this week..] AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL |
Thanks zedsn, I'll take a look at that option... probably end up welding it. On a related note, I'm having one hell of a time tryng to remove the O2 sensor... looks like the original is still on there after 20 years. Tried warming it up, WD-40ed it...ain't budging. What a PITA.
O2 sensor removal
I too had a heck of a time removing the O2 sensor. Seems the threads were a little messed up. I had to heat mine with an acetylene tank and had to get the pipe cherry red as well. Ed.
I bought an aftermarket direct fit cat on ebay March '06 for around $70. Brought it to meineke and had them do the R&R (welded) for another $50. Took the opportunity to have them replace the original catback with a new Ansa exhaust as well.
Came out flawless. Passed inspection w/o problem. The original cat must have been severely congested - the replacement significantly changed the responsiveness of car when revving. Definitely less sluggish. ymmv tho.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
Banned
Brand or seller id? |
Hope this helps.
Hi, just get yourself a generic cat. Measure your pipe first, diamiter and the lenth of the total opening as as they make them with different pipe sizes and different length of the cat itself. I believe most of your discount auto parts store will carry a universal cat.
I got a Magnaflow Hi-Flow for $60 bucks, and had it welded on. Its about 1/3 the size of the original. I eliminated the pre-muffler (resonator) too. Car sounds throatier, and is more responsive. I added a K & N too, I figured more flow out needs more flow in to balance things out.
Rick, Chatsworth, Ontario, Canada 1988 944S 18" 993TT wheels Magnaflow hi performance exhaust K & N air filter and MaxHP Kit chip |
Thanks for the feedback guys. I ordered a direct fit eastern CC (hi-flow)..... took me awhile to find an internet place that sends exhaust parts to Hawaii...not sure what the logic behind that one is.... I like the idea of putting an Ansa on too, the original muffler looks a little beat... guess I better save my pennies. - Chris
Banned
thread resurrection -
I finally passed smog today. here's what I did: 1. Change the oil 2. Replaced O2 sensor ($20 on ebay - universal type) 3. Changed the cat ($180 including labor). The new cat is some no-name thing from "Magic Muffler" that is 13 in. long. 4. 15%-20% xylene 5. Disconnected one fan because I have a 160* Thermostat and I wanted the car toasty. It ran up at 3/4 guage while on the smog dyno. worked like a champ. "NO" went from a failing 1250 to a passing 88. wahooo
