Custom User Title
Summer Project - Suspension
Some of this stuff is already purchased or is on its way but let me know how this sounds;
Front Koni struts Weltmiester 250lb springs (with spacers so stock height) currently have 24mm sway bar but will be going to 26.8mm bar new bushings for sway bar Rear Koni stock Tbars (23.5mm) 18mm sway bar with new bushings |
Sounds good so far... costs???
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Sounds like she might push a bit - I'd be considering 19mm rear Cup Car bar, if not bigger, unless you're getting a good deal on the 18mm rear bar... in which case I'd recommend trying without the front 26.8 bar first.
Just seems unbalanced.
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
Custom User Title
As it sits with the 24/18 bars the car is fairly balance but it just rolls way to much. I am hoping that this is because of the original shocks and struts
The bigger bar and new bushings in the front should help the roll.
Custom User Title
front bar from local dismantler - $150 Springs from a pelicanite - $80 new rear Konis - $260 bushings, bump stops, shock boots etc. $ 120 |
White and Nerdy
The sway bar bushings where shot on my '84, I just replaced them, and several other worn components with play, car is soo much better.
Shadilay. |
Not a bad deal. Do they make a front bar as big as 30mm or is 28mm the biggest? I have a HUGE front bar and ordered new bushings a couple months ago. I don't remeber the size off hand. I had the front bar off the car for a day. Boy did it make a difference when I put it back on! My car doesn't roll at all. Maybe it's because it's just an n/a...
Custom User Title
This is by far the most ugly picture I have of my car but I think it shows what I am trying to correct
That is HORRIABLE! I think the springs will make a big difference. I don't drive mine on a track, but hard turns on exit ramps gets no roll. I got tons of roll with the bar off.
or we'd say "that's got body roll so bad that the doorhandles scrape when you turn the wheel." obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car. Last edited by Obin Robinson; 07-08-2007 at 08:34 AM.. |
Yeah, that's why I've always run the 19mm bar - it's far cheaper than the Weltmeister crap:
http://www.*****************.com/product_p/968m030rearsway.htm $150 with bushings!
I think my car rolled like that with NO front bar on it.
Custom User Title
Custom User Title
Re: Summer Project - Suspension
The rule of thumb should be to match the springs/torsion bars to get the handling close to neutral then use sway bars to fine tune the balance. IMO, with 250 lb springs in front you should be balancing them out with 27mm, 28mm or 29mm torsion bars depending on your preference towards understeer / oversteer at the limit. For auto-xing I would have gone with a softer spring in front to get more rotation in the tight turns.
Mark '86 944NA '10 VW Golf 2.5 5sp '99 BMW 540i Sport Wagon Last edited by mlue; 07-10-2007 at 08:24 PM.. |
Custom User Title
I know the rear torsion bars are going to be soft. But I have been thinking of adding the 19mm adjustable bar in an attempt to make it a little more neutral. If that doesnt work well I would change out the torsion bars but that would have to be next year.
I have spoken with 1 shop and they told me to use my existing sway bars with new bushings, change the struts/shocks and springs. This shop tends more towards full blown coilover set-ups though. |
Of course, if you do the torsion bars next year, that's going to change everything, and you're back to square one - at very least, needing different front springs. You definitely won't want to have to change t-bars twice!
Custom User Title
I would upgrade the front bar to a 30mm if I upgraded the torsion bars to match the front springs.
Im getting annoyed with the whole torsion bar thing |
Writer/Teacher
I did a lot of suspension work to my 83 944 - 220lb springs, Koni yellows in the rear, bilstein sports in the front, turbo S sway bars all around, strut tower brace - but since I did the mods a little at a time, I didn't really feel a drastic difference as I went along...
When I got my 951, it was clear to me that I had made my little 944NA a very nice-handling car. The 951 handles well, but... well... I think suspension will be my winter project.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
