Below the Rim
jjone20's Avatar
Alt. Light On/Key Off
My 924 has the alternator light on with the key off. Where to start?
1979 911SC Coupe
Old 09-28-2007, 10:24 AM
bearone2's Avatar
any other lites, oil pressure on? key off may not be grounding the ignition switch.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 09-28-2007, 11:05 AM
Politically Incorrect
onZedge's Avatar
I hope it's this simple...
With the key off and alternator light on, do you also have battery voltage at the black wire to the coil? If you do, you probably have a bad ignition switch. The voltage for the idiot lights and coil on a '77 924 ONLY comes from the ignition switch ON position. I looked at a '78 924 schematic. Should be the same.
Edek
'87 924S
'91 535i
Old 09-28-2007, 04:23 PM
kwikt 911's Avatar
Check you wires that go to the starter... it happened on my 911. It was a broken connector.
Kevin
Old 09-28-2007, 05:39 PM
Just thinking out loud
mattdavis11's Avatar
after you do that check 924.org I'd like to help, but i know nothing about pre-80's 924's
91 FJ80
84 Ram Charger (now gone)
Old 09-28-2007, 05:48 PM
Below the Rim
jjone20's Avatar
Found it. Brittle insulation around the harness connecting the starter and alternator had flaked off causing a dead short. Too many heat shields to get around, but its out and now I have to rebuild that portion of the harness.
1979 911SC Coupe
Old 10-02-2007, 06:04 AM
onZedge's Avatar
Do you have a picture of this?
Edek
'87 924S
'91 535i
Old 10-02-2007, 03:18 PM
