In over my head
Anti Seize on intake manifold bolts - good or bad?
I am about to reassemble my intake manifold after doing a venturi delete. I know that the bolts (the 8 socket head cap screws) can often be hard to remove. Does it make sense to use anti-seize on them to ease the task next time? Is there any risk to doing so?
Thanks in advance.
Fergus
86 951 Graphite Metallic
86 944 n/a Garnett Red Metallic (SOLD!)
74.5 Triumph TR6 (restoration project)
05 Subaru Legacy (winter car)
Old 04-23-2008, 02:05 PM
That Guy
Techno Duck's Avatar
No risk. Check and retorque after a few hundred miles. The problem with antiseize is it makes it very easy to over torque fasteners especially in our butter soft aluminum blocks / heads. Generally there is a specific value you should add for anti-seized fasteners (in addition to the factory #). I am not a fan of having to over torque anything on the aluminum block or head personally. Helicoils are easy to do, but i dont like them that much.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-23-2008, 02:58 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I don't use anti-seize but I normally add a little bit of blue loctite. Those bolts like to back out.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 04-23-2008, 03:58 PM
