So b/c it is getting colder i decided to check my antifreeze. I open the cap only to find a whitish gray goo on the cap and in the tank. I took some antifreeze out of the tank with a turkey baster and found that it had oil it...perfect way to ruin a Sunday btw.
Question does any one know what could be causing this and how hard is it to fix? Also i checked the oil and it is clear. The car had had bent valves repaired at Storks in Dallas shortly before i bought it and that was only like 2-3k miles ago. i will post a pic of the antifreeze once i get back out there with a camera. any help would be greatly appreciated. |
Oil cooler seals. Easy fix for one afternoon or morning. Remember to flush after fixing
1987, 944S (168,000 miles)..sold 1986, 944na. My job is a hobby. My 944's are work. |
Writer/Teacher
It's one of two things: bad oil cooler seals, or a blown head gasket. Pray for the former.
Check your oil on the dipstick. Does it look normal, or is it "milk shakey"? If it's milk shake, you have a bad head gasket almost 100% of the time. This is comparatively big bucks. If it isn't, it's proably just oil cooler seals, which is common, comparatively inexpensive, and easy on NA 944s.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Thanks for the help so far you guys are easing the depression.
I have some pics of the antifreeze if it helps. ![]() ![]() the first one is the antifreeze and the second one is the go that got on the baster while removing said antifreeze |
Greasy Member
My $$ is on the oil cooler seals. It's not too bad of a job, but I recommend getting ahold of the alignment tool to install them!
Good luck! -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
unindicted co-conspirator
++ on the alignment tool. Makes it MUCH easier to put back together correctly
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Super Moderator
it could also be the head gasket.
an easy way to check is to use an emissions 'sniffer' (any emissions or dyno shop should have one) on the coolant reservoir with the cap open and the motor running. if the head gasket is blown, it will pick up faint exhaust emissions readings from the coolant.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Also try a leak down test & listen for air escaping Testing the coolant resevoir for hydrocarbons could give you a false reading with oil (hydrocarbon) in it.
Super Moderator
aren't hydrocarbons only formed from combustion?
yes...
my bad Maybe if the oil is burnt??
Wouldnt there be water in the oil if the head gastket was blown?
Super Moderator
it is also possible for the hg to be blown in such a way that oil only leaks into the coolant during combustion one-way. it's happened to me before.
k...i already have the seals for the oil cooler on the way and will change them on sat. the flush the system. Do i need to change the oil while i have it all apart? i just did it less than 1,000 miles ago. If its not the oil cooler guess i get to learn how to do a headgasket
Could it be a leak from the water pump?
Redline Racer
When you do the oil cooler seals, try to take the exhaust manifolds off. It is a truly horrible experience with them on.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Super Moderator
Super Moderator
no. there is no chance for passage between coolant/oil in the water pump.
winter-hater club member
no. hydrocarbons are what you car burns (and your body in the form of glucose). hydrocarbons are carbon/hydrogen chain molecules. thus, true octane is a chain of 8 carbon atoms with 17 (i think) hydrogen atoms attached.
combustion byproducts are H20, C0 (due to insufficient O2 in the mixture) and CO2.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
