-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   87' 944S Timing / cam gear cover problem (http://forums.pelicanparts.com/showthread.php?t=374339)
PatrickG 10-27-2007 02:11 PM
I was changing my water pump, timing belt last nite and noticed that the rear cover behind the camshaft gear is broken at the mounting tabs. I took a look at the distributor cap and seen that it is barely making contact with the rotor contacts...
I took off the camshaft gear and this is what I have..:( I don't think it can be fixed, I really don't know how this happens to a cover that is completely covered up. Maybe someone over tightened the 2 10mm bolts and cracked the tabs. 1 tab is completely broken off and the other one is cracked and bent upward. It has been this way for a long time, it almost looks like it has started to corrode away. There is no way that I can "just" put it back on without some modifing the tabs and cover to fit again.
I checked Pelican parts, Zims and a few other places on the net and it is NLA at all the sites.
It is #28 on the attached photo from pelican parts.
Does anyone know if I can "fix" it by getting it welded and if someone has one for sale??
Thank you in advance for any help.....http://forums.pelicanparts.com/uploa...1193519458.jpg
http://forums.pelicanparts.com/uploa...1193519500.jpg
callmethewander 10-27-2007 02:23 PM
can you drill it out from behind and stick a bolt through and use a nut on the front?
Dtchy 10-27-2007 02:51 PM
There's people parting cars all the time. Someone should have one for sale you'd think...
idontknow 10-27-2007 02:53 PM
clean it up, JB weld it
speedracing944 10-27-2007 03:28 PM
I vote finding one off a parts car.
Speedy:)
fast924S 10-27-2007 05:43 PM
Parts car, Or JB weld works and is very strong
callmethewander 10-27-2007 07:49 PM
hey, IDK, how bout throwin' some pix of the Karman up here, we'd love to see 'em.
PatrickG 10-27-2007 08:35 PM
Speedy:)
I am in the process of finding a suitable replacement, but I won't overlook the cheaper fix.
I thought of cutting off the tabs and finding a "spacer" that is the same length as the broken tabs. Drill it out and nut and bolt it up. I have sometime to look since I have any extra car to use while I work on the 944.
callmethewander 10-28-2007 03:58 PM
but, there is no substitute
PatrickG 11-18-2007 04:56 PM
Finally got around to writing an update..
I purchased a used cover from a local guy that just happened to have it "laying" around. $30 for both sides of the cover.:D
While I was down for a while I took off the valve cover and had it Powder Coated Silver and painted that used timing gear cover.
I also changed the Cam belt, balance shaft belt and water pump. And since I am never happy with stock I also "made" a custom 3" cold air intake for my S.
pics to followhttp://forums.pelicanparts.com/uploa...1195433641.jpg
http://forums.pelicanparts.com/uploa...1195433698.jpg
http://forums.pelicanparts.com/uploa...1195433737.jpg
http://forums.pelicanparts.com/uploa...1195433798.jpg
callmethewander 11-18-2007 05:08 PM
Where is your timing gear and balance shaft belt cover?!?!
PatrickG 11-18-2007 06:14 PM
On the way to the landfill.....:D
I am keeping the rear cover but only for retiming the cam balancer belt.
callmethewander 11-18-2007 06:22 PM
Why? doesn't that should be on there?(sic)
