Question about removing the Wiper fluid bottle
I was wondering about the Wiper fluid bottle? I have a crack in mine and I was going to try and remove the bollte and see if I could find and fix the crack, but I can't seam to get it out. Is there another bolt in the bottom area? Something else holding it in? Easiest way to get it out? Thanks Mike
I Love the Smell of Jet Fuel in the Morning! 86 Silver Porsche 944 N/A - Alpine CDA-9857 KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade http://www.c28.com/?adid=st&iid=25349 |
I took mine out through the bottom, it seem easer for me and yes their is two bolts in the bottom.
Brian 1983 Porsche 944 Silver with Brown Interior. 2005 Honda Goldwing 2000 Husaberg 400 2001 Sherco 2.9 1968 Honda CT-90 2001 Arctic Cat 500 Auto 1998 Toyota PU 2001 Toyota Highlander AWD 1991 Tiffin Motorcoach 2006 Suzuki 450 Super Motar |
Politically Incorrect
I has to come out from underneath. BTW, it holds a suprisingly HUGE amount of fluid.
I'll have to remember to empty that thing if I ever get to a DE. It's worth about 15-20 lbs.!
Edek '87 924S '91 535i |
Thanks Everyone! I will be removing it over the next few days, When I am changing my bushings and it is jacked up, I will take care of everything. Thanks and I really appreciate the site! Mike
One other thing, have your headlights in the open position. Good luck with the job.
Max Hofer 1985 911 Turbo-Look 1985 944 NA Santiago - CHILE |
