pull the end cap off the fuel rail and with rags covering the output see if you have fuel to the rail when cranking the car
be careful when you take that fuel rail cap off... as there is a little ball that likes to escape !
it gets fuel, ive pulled the cap off and fuel filled up a bowl pretty fast.
good, you have fuel to the rail and spark: check that the injectors are firing and the qualiy of the spray if possible by raising the rail and cranking....
| All times are GMT -8. The time now is 06:58 AM. |
