What spring/bar rating should I use for a street/track car?
I'm going to re-do the suspension on my '88 944 this Spring and need to decide what spring/bar ratings to use. The options are from 250-350 lbs. up front and 27-30mm for the torsion bars. If I max it out, will the car be intolerable on the street?
I currently do about 6 or 8 track days (3-4 events) per year. The rest is weekend, or sunny-day usage. I do not foresee converting this car into a 100% track car (it's too pretty!). I can tolerate a very firm ride, but within reason. |
The 250 lb springs up front, and 27 mm Torsion bar in back would make a good street/track combination. You want to keep a balance with the front and back spring rates. Going stiffer in the front (300 lb) will induce a little more under-steer, which you may, or may not want.
A 30 mm Torsion bar in back should be balanced with 400-450 lb springs up front. This is our current race setup, and is probably too stiff for regular street use. YMMV good luck JM :cool: |
Many thanks!!!
Assuming you're on smooth, well chosen roads for pleasure driving (plus track usage), and not chugging through the daily commuter routes, I'd go for the stiffer option: 300lb/28mm, and lowered an inch or 1.5".
Check this out if you haven't already (and don't forget your sway bars!) http://www.clarks-garage.com/shop-manual/susp-15.htm |
I have 250lb springs on my car along with konis shocks and 16inch rims so a slightly lower profile than stock. I really like the setup and have taken the car on multi hour drives and dont find it too harsh at all.
I dont know if Pelican would match the price but I would be worth asking them. |
I'm hoping to achieve a balanced car with minimal understeer. The "package" has dual Weltmeister sway bars in addition to the other stuff. |
What about kw coilover variant 3? or jrz if you have the big bucks?
The koni all the way =)
weltmeister springs 250 or 275 lb springs 27 or 28mm torsion bar front/rear 968 M030 sways, with the rear sway at its tightest setting or 300 or 325lb spring 29mm or 30mm torsion 968 mo30 front sway 22mm adjustable rear sway |
or even the bilstien escort cups package on lindsay racing or paragon
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=944SUSESCORT http://www.*****************.com/product_p/bilstein_escort_cup_944.htm |
Interesting. So, compared to the "Spec" package offered by Paragon ( http://www.*****************.com/product_p/944spec-3.htm ), the Escort Cup (for a bit more cash) lacks the weltmeister sway bars, but offers a more adjustable package and easier install (assuming I do not change sway bars, and I just buy the rears as "boosters" to the OEM torsion bar). For calculating effective spring rate, what is the OEM diameter of the rear bar on the 944? Any thoughts on whether I could get away with OEM sway bars (spaghetti) with the Escort Cup package? (Because if I need to add sways, it gets pricier.) Escort Cup also appears to be VERY firm stuff. They recommend 700-800 lbs on the springs. That's pretty stiff! |
My car has bilstein turbo cup suspension, from what i have read it is similar to escort cup but stiffer, and i think it has oem sways. The car was tracked a few times with this setup and i have never herd any complaints.
I'm also in the process of figuring out what my replacement will be |
This raises another question. If I use the coilovers as a booster to the OEM torsion bars, I obviously cannot drop the ride height in the rear unless I re-set the rear torsion bars. But how do I avoid ending up with a higher rear ride height (without re-setting the rear torsion bars)? (PS: Jason, why are you replacing the turbo cup suspension?) |
At this point i've moved over to rennlist =) if you don't know you will now, very large porsche community including us the specialty crew owners
I posted your question, here is the link http://forums.rennlist.com/rennforums/showthread.php?p=5026720#post5026720 |
the suspension is 20 years old =D and it really squats when floor it and there is better tech out there now
The car is 22, ie 86 |
reno808
Addict Rennlist Member "ahhahahahahah THIS HAPPENED TO MEEEEE and its high right now lol. ight their 2 things you can do one order 6in or 7 inch springs i have 8 inch which is why my car is jacked up so i used the encentric bolt and it lowered it a bit but i am still higher than stock. and/or you can use the encentric bolt but not that much help just order 7 or 6in spring. Just remember you can only move a 1/2 in down with the encentric bolt if i am not mistaken. If you want really want to get real close to stock get a 7 inch and play with the encentric. I am going to order new springs this month coming up and i think i might play with the t-bars" |
| All times are GMT -8. The time now is 04:19 AM. |
