ace_944's Avatar
Porsche Crest Wiring problem need help
I was working on some of my wiring and saw this wire, I was gonna try and follow it back to see where it went and before i could it popped off whatever it was on. So if anyone knows what this is and where it goes it'll be a big help.
Old 02-06-2008, 09:41 PM
What was it near? It doesn't look stock...
'87 924S (Sold)
Old 02-06-2008, 11:03 PM
GostRidr's Avatar
Year and model might help.
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 02-07-2008, 01:00 AM
it looks like a thermostat(like the one you have in a fridge) to switch AC on and off
Old 02-07-2008, 05:09 AM
Connector for oil level sensor.
Good luck, George Beuselinck
Old 02-07-2008, 05:36 AM
ace_944's Avatar
its a 87 944 n/a and it was on the same wiring harness as the oil pressure sender. All the wires on that last tail were melted.
Old 02-07-2008, 06:54 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Passenger side, just above or at the top of the oil pan towards the rear portion(engine) apprx 1/2 way up from pan bottom. Triangular shaped plate with screws and the port the connector insert into. Once you see it you will know it goes there because the shape is unique.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 02-07-2008, 08:13 AM
Low Oil Warning light Plug. 924Sman has it.. It just slips back on like a spark pluge wire.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 02-07-2008, 06:57 PM
ace_944's Avatar
Cool, got it all hooked back up. Thanks for all the help guys.
Old 02-07-2008, 11:29 PM
