rporzio's Avatar
Front Porsche Emblem
How do you replace the gasket for the front hood Porsche emblem on an 84 944?
RPorzio
84 944
Old 02-06-2008, 10:37 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
it should be stretched over the badge. Some have let it sit in boiling water to lossen it up and then putting it on the badge and then bolting to the car. Others have used a heat gun or hair dryer.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 02-06-2008, 11:12 AM
Not Special
Also, on an early, the header panel is spot welded into place, while the later cars are attached with screws.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 02-06-2008, 11:31 AM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
I replaced mine, got it pretty cheap on eBay, authentic. I was able to get my had behind it, gasket did not fit extreamly well, I should have heated it up. Makes the front end look alot better, just from that. Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 02-28-2008, 06:34 PM
Keithr726's Avatar
Send a message via AIM to Keithr726
The gasket is really annoying. It takes time and would be easier with three hands. I found a dab of instant glue helped.
Keith
1986 Porsche 951
Old 02-28-2008, 09:37 PM
In the Fires of Hell.....
kdjones2000's Avatar
Here is what Ian at 944 Online had to say about the emblems.
The normal emblem for the 944 uses the rubber grommets that you insert from the top side of the nose panel. The emblem and gasket are just inserted together into these grommets using a friction fit. This is the only option that I know of for the welded-on nose panels on early 944's.
Some people sell Porsche emblems with the metal nuts that screw on the backside. These are for 911's, not 944's.
Hope this helps a little bit - I know that I was confused about this when I was buying a new emblem for my 951.
Cheers,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-29-2008, 09:07 AM
Ya it just pushes in... Get a heat gun and just take your time and that gasket should be no problem.
Old 03-01-2008, 08:31 PM
