Kevins911's Avatar
'84 944 Engine removal, what's it caught on??
I'm pulling the engine on my friends '84 944, I was originally going to just do a top end and leave the engine in. But we decided to pull it completly, check it all over, clean and reseal it. Plus I can check the clutch at this time too.
So, heres the problem...the engine is down to the short block, head removed, exhaust is removed, the 4 bolts that hold the engine to the bell housing are out, all hooked up to the hoist. I cant seem to seperate the engine from the bell housing, it will only come appart about a half inch, am I caught up on the throw out bearing and releas fork?? If so how do I get these appart?
Kevin
'73 914 2.0L
Old 03-24-2008, 10:02 PM
meister member
speedracing944's Avatar
are the speed and reference sensors removed from the top of the bell housing?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-24-2008, 10:13 PM
meister member
Speedy
Old 03-24-2008, 10:15 PM
Kevins911's Avatar
yeah, ahh, I figured that out the hard way, I broke the mount but at least the sensors are out of the way now!! It's still caught up on something.
'73 914 2.0L
Old 03-24-2008, 10:26 PM
meister member
I know there is a pin which hold in the clutch fork but I can't remember off hand if that would stop you. Do you have that removed. It is pulled from the bottom of the bellhousing.
Speedy
Old 03-24-2008, 10:37 PM
meister member
BTW got to get some sleep. Good luck.
Speedy
Old 03-24-2008, 10:38 PM
Kevins911's Avatar
I dont have the clutch fork removed, I'll take another look tomorrow. Thanks!!
'73 914 2.0L
Old 03-24-2008, 10:42 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Mine was stuck pretty tight too. Turned out that the pins going from the bell housing into the motor were hanging and when I pulled them apart straight, it just fell loose.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-24-2008, 11:33 PM
Kevins911's Avatar
hi tom, it seems to be far enough apart that the pins aren't an issue, maybe its binding up on the torque tube, like the shaft that goes into the clutch disk. I'll try putting a jack under the torque tub tomorrow and see if that helps.
'73 914 2.0L
Old 03-24-2008, 11:46 PM
It is hanging on the clutch fork. It comes out from the bottom of the bellhousing. There is a long bolt that comes out from the bottom and then you can slide the fork out. Getting the bolt out may be tricky if it is stuck in the fork, but some patience will get it done. I wrestled with mine for around a half hour before it come out. Once the fork is out, the engine should come right out.
'89 NA
Old 03-25-2008, 03:20 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Why dont you remove the 4 bolts that attach the torque tube to the bellhousing instead? having removed an engine or two, this is by far the simplest method. then you can get to the bellhousing & clutch with the ending out of the car. Much easier that way.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 03-25-2008, 08:40 AM
Back from Beyond
^+1. Be careful you don't mash the hood latch receiver. Going out the top?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 03-25-2008, 11:00 AM
