-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Need some advice. Just found out I have a turbo block in a N/A car. (http://forums.pelicanparts.com/showthread.php?t=400738)
tryangles 03-28-2008 08:33 AM
As stated above I recently found out after months of work putting this engine back together that it is a turbo block. The problem is that it is in a n/a car. What are my best options to get this car running? What kind of $$ am I looking at to buy all of the turbo parts? Would it be easier to swap in n/a pistons? I dumped alot of money buying new parts to get this running right and now this happens!!
nynor 03-28-2008 09:15 AM
well, if it has the NA pistons, you are ok. if not, you will need to change the engine out, change the pistons, or turbo/supercharge it. turbo/supercharging will cost you more than buying a 944 turbo, almost for sure.
what i am trying to figure out is how you put the engine back together and didn't know it was a turbo block and/or had turbo pistons.
tryangles 03-28-2008 10:16 AM
Well, the longblock was already assembled. The guy that I bought the car from was planning on putting in a LS1 so he was taking everything apart. The previous PO was the one that had been working on the engine.
nynor 03-28-2008 10:18 AM
hmm... it is possible that there are NA pistons in there, but i doubt it from your compression numbers. what a bummer. the upside is that you can sell it and get an NA motor for less money than you sell it for, most likely.
tryangles 03-28-2008 10:28 AM
If I take the head off, how will I be able to tell if they are n/a or turbo pistons??
Techno Duck 03-28-2008 10:43 AM
The shape of the piston tops is different.
Turbo pistons
http://img.photobucket.com/albums/v1...b/IMG_6009.jpg
N/A pistons
http://img.photobucket.com/albums/v1...b/IMG_3636.jpg
nynor 03-28-2008 10:57 AM
i'd at least attempt peeking in the spark plug hole before you go to the trouble of pulling the head.
tryangles 03-28-2008 11:17 AM
I will do that. I pray that I don't have to!
callmethewander 03-29-2008 08:00 PM
what's the difference in the actual block? anything?
v2rocket_aka944 03-29-2008 08:31 PM
block and crank are the same, the difference was pistons and heads. iirc the cam was the same too.
nynor 03-29-2008 08:40 PM
different durations on the cam.
