Eldorado's Avatar
dme relay
driving around the other day, my car kept dying... i'd go to start it and it'd just crank and crank and crank... it would start and then either die immediately, or let me drive it another block or two but die again.
I've had major vac leaks in my car before and this doesn't feel like that... there's no sputtering or anything.. it just *shuts off*.
not the ignition switch because coasting after my car shut down i wasn't able to put it in gear and pop the clutch to start it...
I'm leaning on dme relay...
with that said, where is it located on the relay board on the early cars?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-23-2008, 01:50 PM
Custom User Title
Dave L's Avatar
sounds like the DME relay to me, my 8v used to do the same until I replaced the relay.
location;
http://www.dietersmotorsports.com/tech/2001/DME_relay_failure.htm
Old 04-23-2008, 02:06 PM
Back from Beyond
Ignition switch. My $.02. Easy fix and cheap place to start. Have you tried jumpering the fuel pump yet, Kyle?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 04-23-2008, 03:31 PM
Send a message via AIM to bholmes
clarks tells how to jump the relay, it's an easy and cheap way to see if that's your problem, all you need is a few peices of wire and some crimp on electrical connections. I used to keep one in my car just incase.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 04-23-2008, 03:42 PM
earlr85944's Avatar
its in the worst spot they could have put it, but eas enough to swap and see if it repairs the prob, I think its the 2nd relay from top left
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 04-23-2008, 06:12 PM
earlr85944's Avatar
it is #2
83 944....bye bye
Old 04-23-2008, 06:20 PM
Eldorado's Avatar
thanks for that.. clarks nor the other site listed the 83 location....
Kyle
Old 04-23-2008, 10:27 PM
AKCJ's Avatar
Kyle,
My DME relay went out last summer. The good news was that I had a spare in the glove box. The bad news was that when I went to put it in the relay base just hinged backwards so the relay did not connect to the base. From the front side it looked fine. I figured it out after getting a tow home.
Just something to watch out for.
Jerry
Red 83 944
Old 04-25-2008, 09:47 AM
