-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Side Mirror Question (http://forums.pelicanparts.com/showthread.php?t=405585)
ColoradoSteve 04-23-2008 02:50 PM
The mirror on the driver's side is loose, does anybody know how it's attached? I'm assuming there's some kind of screw that is holding it on from behind the door panel but it would be nice to know before I start taking things apart. I guess I could just super glue it......
Thanks,
'83 944
#391 04-23-2008 03:02 PM
Not sure if the '83 is the same, but on mine there is one screw holding it onto the door. Push the mirror assembly toward the front of the car. You will see a small black cap in a hole. Use a tiny screwdriver to pry the cap out. Under the cap is the bolt head, use a hex key to remove/tighten (make sure to use the proper metric size so you don't strip it!)
ColoradoSteve 04-24-2008 05:54 AM
Thanks!
