Spark plug wires
Did a search and didn't find anything. I was checking the spark plugs on my 86 944 and when I pulled the first one there was a fine whiteish blue dust that came out. Reminds me of corrosion on a battery from battery acid. What do you guys think is wrong? Should I clean the one wire out and reuse or just replace. It's only the first plug wire.
Thanks, Matt |
our host sells performance wires for only like $80. it's about the cheapest you will find.
dolor et pavor Copyright |
Per wire correct? Or is that for a set of four? I'm assuming per wire cause most sets are 200+. If so would I have to replace all four wires or just the one that's "bad"?
Trying to work for parts!
Go look at the parts section. It's called a wire set...meaning all 5 wires.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Learned by do'n twice
Set of Bosch wires on ebay every day for $80. Just installed a pair on our 86 944 NA.
jmd_forest
86 944 NA - Brought back from the dead |
