PorscheJeff95
HELP: Master Cyl or Booster?
Need some help guys; how do you determine if the brake booster is bad or the master cylinder is bad?? I have a leak at the seam that mates the booster to the master cylinder wall...it leaks just sitting there over night....the nuts are tight....please share your thoughts...thanks
Old 05-07-2008, 07:48 AM
924RACR's Avatar
What leaks, fluid or vacuum? The MC holds fluid, the booster holds vacuum (keeps air out?).
You do the math...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 05-07-2008, 10:35 AM
i had a vacuum leak that turned out to be the booster...god-awful most difficult job ive ever done on the car haha. sooo uncomfortable.
Old 05-07-2008, 02:49 PM
Send a message via AIM to bholmes
The seals in your master cylinder are out. they can be rebuilt pretty easily I think then you just have to bleed your brake system, fun fun.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 05-07-2008, 05:36 PM
