968 won't start
Need info on 968 diagnostics and do not have a Bosch hammer.
The motor turns over but will not start. Switched out the ECU on another car yesterday, and prooved it is good. There is no spark or fuel pump operation. I tried another DME relay(used), and same thing.
Is there info on testing the hall sensor and speed sensors anywhere?
Any help would be appreciated.
Old 05-07-2008, 08:59 AM
You can test the flywheel sensor with an oscilloscope.
The hall sensor is not used until the car is running (to identify which cylinder is creating a knock).
You can check for injector pulse with a noid light.
Good luck, George Beuselinck
Old 05-07-2008, 09:06 AM
flash968's Avatar
tried a blink test yet?
Old 05-07-2008, 11:18 AM
Quality
phoenix_iii's Avatar
Does the tach bounce (944 ppl like to know this so I assume it is still relevant)
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 05-07-2008, 12:01 PM
Hey George:
We have to stop meeting like this. I'm still trying to get things in order. Thanks for the help. Maria says hello.
Old 05-07-2008, 01:00 PM
No bouncing tach. Thanks
Old 05-07-2008, 01:11 PM
ok whats a blink test? Thanks
Old 05-07-2008, 01:12 PM
flash968's Avatar
it's a DIY test that will make the fault codes pop up - drop me a note and i'll send you the link
Old 05-07-2008, 02:28 PM
