Little confusion on Timing Balance Belt Adjustment
Ok,
Maybe I am missing something ??? If I am making adjustments to the timing and balance belt use the Arnn Worx Gauge Kit...do I need to set everything and TDC...which means, do I need the Flywheel lock to make adjustments the belts ???
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
Writer/Teacher
I think you should absolutely set the car to TDC; when you tighten or loosen the belts, the cam or crank gears might move accordingly. It's best to make sure that you start AND finish with both gears at TDC.
Don't worry about using the flywheel lock for this. Just make absolutely sure that you are at TDC before you start the car.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Redline Racer
...that you are at TDC and the timing gear mark is aligned before you start.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
meister member
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Ok, I will do that
Custom User Title
As long as the belts stay on the pullies, it's not necessary to find TDC.
If you're just tensioning a belt that's already been replaced (say checking the tension at 1,500 and 3,000 miles) then just go for it. The only time you need to set everything at TDC and put on your flywheel lock is when you're actually going to take the belts off.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Just thinking out loud
As Mike said, there is no need to find TDC. Vice grips or other will hold the belt on the teeth of the pulleys to keep it from jumping time/balance if you make a mistake while you make your initial adjustment. Do not keep them on, for obvious reasons, while you make final adjustments. You don't need a flywheel lock for any 944 maintenance, it's a waste of time/money if you ask me.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 05-25-2008 at 08:43 PM.. |
So say I am replacing the belts, as long as I keep the crank from moving then it does not matter if I have a Flywheel lock ? In addition do I need the thin wrench??? Or can I adjust the 27mm bolt with a standard wrench ???
This entire theory makes no sense ??? If I went in and took all the belts off with no care at all and before installing the new belts I adjust the crank and cam to TDC/ and the Balance shafts until the knotches allign before I install the new belts everything should be fine...?
Trick off the trade, the best thing before you takle anything with the timing on the car, the best thing to do first is the set the gear on TDC.
I find the best way: Iis find the crank mark on the window and then line up the crank mark to the bell housing mark, that way you are sure you are on TDC. Don't forget: Crank rotate twice while the cam rotate once ! Good Luck ------------------------------- Bud |
You don't need a flywheel lock, you don't need a calibration tool, and you don't need a special thin 27mm, but you do need new belts and may improvise on the wrench. Mine is a cut down, bent, shaved, and rusty 1 inch wrench that had been laying around for 30 years.
You aren't going to accidentally roll the motor over without knowing. The cam is a different story, but even blind men can get that dead on balls accurate every time. Put a couple of dots on the crank gear and housing if you are worried about it. The only time I have ever thought I needed a flywheel lock was when I was having a hard time busting the crank bolt loose, but even then I didn't need one. Timing/balance belts are so simple guys, quit making it difficult and get out there and change the somebytches.
83 944 91 FJ80 84 Ram Charger (now gone) |
Back from Beyond
mattdavis11 - love your approach! ^+1
Everything has timing marks - crank, cam sprocket, balance shafts. Plus, if you're careful while you're turning the engine by hand you'll feel if something isn't right. As far as tensioning goes, I use the krikit and drive new every two.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
