What's the odds....
Does anyone know the odds of needing the sleeve/bushings when doing a front reseal job? I can save around 60 some bucks by just putting seals in it. I hate to pull it apart enough just to check, put it back together to drive, and then pull it apart again to fix. Is this a pretty common problem?
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
Politically Incorrect
At least the sleeves are replaceable...
I just did this last weekend. I ordered the front re-seal kit with the cam and balance shaft sleeves. I had no idea when/if they were changed before. It has ~125K miles on it (broken odo worm pinion gear). The b/s sleeves were fairly worn but the crank sleeve was toast. I should have ordered the crank sleeve at the same time. I haven't taken the cam tower apart yet, but I have a new sleeve ready already.
NOTE: The crank seal that came out was 38 x 52 x 7mm. The new seal is 38 x 52.2 x 7mm. There must've been a TSB about the change that I missed...Anybody know anything about it?
Edek '87 924S '91 535i |
Redline Racer
mine had the 38x52x7 part as well. I didn't check what the exact size of the one Pelican sent, but it hasn't leaked yet, so I'm not too worried.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
