PRMN944
1983 Porsche 944 idle
The idle on my car is acting up. Whenever I start it up cold or hot low idle
surfaced. It has rebuilt injectors, air flow meter, and new crankshaft position sensors. |
Redline Racer
Check for vacuum leaks, especially at the large hoses under the intake manifold (very prone to deterioration), the J boot between the throttle body and AFM, and the intake manifold gaskets. The ISV may need to be cleaned out if it's stuck or sluggish, as well.
Or it might just need to be adjusted. -> http://www.clarks-garage.com/shop-manual/fuel-08.htm
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
PRMN944
I replaced the intake manifold gasket when I changed all those large
vacuum hoses under the intake manifold. The J boot were replaced a few years ago. |
