Quality
phoenix_iii's Avatar
Exclamation Need Help Now! - Car at shop, need wheel hub! Where/Cost??
Apparently my horrible noise and things = the Wheel Hub.
It's the 'thing that goes through the center of the bearing, studs are attached to it, it holds the wheel on', is what I remember from the mechanic over the phone.
His parts guy doesn't have it, another parts person has it for ~$550, + shipping.
I need to know what the part # is, or what it's normally called. Not finding it on Pelican. The rears should be the same side to side.
The wheel bearing froze apparently and erroded the hub. =(
What are my options here? Help!
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 05-30-2008, 07:16 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Just to help ID the part you want........hub
....stub axle
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 05-30-2008, 07:25 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I think there are some on fleaBay right now (was looking for other stuff last night)
nate
1988 944... and a bunch of other cars
Old 05-30-2008, 07:43 AM
Quality
Thank you both. Looking online.
Old 05-30-2008, 07:51 AM
forgot to mention - download a .pdf of PET here
http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
that'll help you find part numbers
nate
Old 05-30-2008, 07:56 AM
Quality
Found a local breaker ('they pull it') that has one. How can I tell if an 85 if 85/1 or 85/2? I have the VIN
WP0AA0941FN473974
*thank you for awesome link
Old 05-30-2008, 07:57 AM
85/1 has the old style dashboard. probably easiest to just call the yard and if they are willing to check for you have them do that. Is the part number different for 85/1 and 85/2? I am at work so can't check PET now.
nate
Old 05-30-2008, 08:09 AM
Quality
Crap!
Do the 85/1 and the 85/2 have the same rear wheel hubs?
Theirs is 85/1!! Are they the same?
I'm thinking no... but the catalog names don't help. The first = 82-85, the second = 85-88... ???
477 501 065 - 85/1 (in E_944_85_KATALOG.pdf)
in E_944_88_KATALOG.pf
951 331 067 00 -86
A 944 331 067 01 87-
944 331 067 01 87-
Old 05-30-2008, 08:12 AM
that says to me, someone please correct me if I'm wrong, that the mid-85 break is probably when they changed from steel to aluminum trailing arms and therefore you need the later ones. I'm ASSuming the 951... part number. '87 is when the wheel offset changed to allow for ABS so that explains the different numbers for 87 on.
I believe that if you had an 85/1 you would look up your parts in the earlier catalog, and if you had an 85/2 you would use the later one.
nate
Old 05-30-2008, 08:25 AM
Quality
I have a tendency to agree (I just spoke with a Porsche dealership too)...
The 'remarks' in the 944(2) catalog say -86 and have the 951 part #... crap. I guess I should fleabay it.
Old 05-30-2008, 08:36 AM
Quality
Thanks guys. I went with the latter two links (found already and sent emails because I need the part now, not in 2 days). I also found a pair of '86' ones that, after printing pic and brought to mechanic, he said they were mislabeled and were the old school ones. He showed me how mine (85.5) are flat, and the old ones are more 'volcano', and he's right. Damn ebay.
So getting the right one online from ebay, I hope. Waiting for email reply.
Mine =
Old/Volcano =
Old 05-30-2008, 09:30 AM
the 2 in the green background appear to be late offset 1987up the blue background is a 1986 email nine01@sbcglobal.net
Old 05-30-2008, 11:04 AM
Quality
Payment sent.
So is the volcano LATE offset and the flatter = EARLY?
Would I have been okay with an 85/1 part? Because I found one locally (40 minutes), but part #s according to Porsche are DIFFERENT. I called Porsche dealer to discuss, they said stick with 951 part (good through 86), and that 85/1 had different (477 iirc, it's above).
Old 05-30-2008, 11:10 AM
I'd bet money the early part was actually a repurposed VW "Thing" hub. then as the design evolved Porsche had to modify the parts.
nate
Old 05-30-2008, 11:19 AM
Quality
I disagree, because I know the VW Vanagon shares the same CVs, I'm thinking it came from there... =)
85 Vanagon = 85.5 944 CV as per partsamerica.
Old 05-30-2008, 11:24 AM
I just realized, I bet we're both wrong. I bet the *924* hub was a "Type 181" part then when the original 944 was introduced it was probably made Porsche specific when it was redrilled for 5-lug wheels.
nate
Old 05-30-2008, 11:37 AM
924Sman's Avatar
More likely Audi. The axle stubs early are from Audi and think the hub is too.
Dal
Old 05-30-2008, 12:06 PM
Quality
cv = VW vanagon iirc.... I feel okay polluting my thread because I sent payment and I am waiting for confirmation. Hopefully get it Monday. =)
Old 05-30-2008, 12:07 PM
