does a turbo cam tower....
does a turbo cam tower and lifters from a 951 fit into a N/A 944.
I believe YES, but Im only about 80% sure
8V. yes, same numbers.
thanks! i'm off to ebay :D
it does have different lift and duration on the cam, IIRC.
so would that affect porformance on a N/A for better or worse?
not sure, but i think the duration and lift on the NA cam is higher and longer, so worse. i could easily be wrong, however.
I'm pretty sure I've heard that, too. The turbo people sometimes use NA cams for that reason.
Yes, an n/a cam is an upgrade to a 951 actually (pretty sure just the early n/a cams).
Why just the early cams? Were they more aggressive, or were the bearing sizes or something like that just different?
http://members.rennlist.com/951_racerx/CamProfiles.pdf
Early and turbo cams are the same. A late NA cam is a turbo upgrade. Since the original poster has an early 944, the turbo cam is the same part number. |
^+1 It's also an early NA upgrade.
Unless you're saying a late NA cam is an upgrade for an early, in which case that makes sense. |
Yeah, that's it. Late NA cam in early NA car. George B set me up with this a long time ago and it did make a difference.
that sums it up.
I have another queston but am kinda lazy to start another thread.
what are the lifters? cam followers or what? also if you have a lifter that collapsed do you just have to replace the lifter or is their anything else that goes on it? |
Hmm, should I tell you anyway?... Nah.. |
i'll take a shot at it. because you're a cool guy? |
the lifters, in our case, are the things that contact the cam and compress the valve springs. if you have a collapsed lifter, you replace the lifter. there are no cam followers (tappets) as such, just the lifters.
| All times are GMT -8. The time now is 03:44 PM. |
