Thanks for the help on the wheel bearing replacement...
After replaceing the wheel bearing I was able to detect a noise and some play in the Tx where the CV shaft mounts. I think I have found the parts diagrams, but I am not sure how to procede with the repair. Are there bearings that are replaceable without removing the Tx? Should I do this myself (reasonably good and thorough)? Any special tools required 1983 944 5spd Thanks in advance
Jack L. Dillard 85 944 78 928 5spd 94 540i Like a cat on shag baby |
Do not replace any of the bearings in your transaxle.
This is not a job for the faint of heart. You have to measure, shim, remeasure and reshim the differential or you will destroy your transaxle. Have a competent transmission specialist do it for you.
Good luck, George Beuselinck |
