Trying to work for parts!
Send a message via Yahoo to hpservertech
Hard brake lines
Anyone know if these are still available new? I know I could get them from some of the guys parting cars. Anyone know of a place that will make them if they are NLA?
Not looking for the stainless ones that Pelican or Paragon sells, but the actual hard lines from the master cylinder back.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-13-2008, 05:21 PM
In the Fires of Hell.....
kdjones2000's Avatar
Have you checked your dealer?
I was able to get the small hard lines for the M758 front caliper upgrade for my Turbo - to - Turbo S upgrade, so I am thinking that they are probably still available.
Also, you should check 944 Online, as they usually have that kind of stuff in stock, if it is available.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-13-2008, 07:15 PM
