Amazing Results from MT fluid change
I was having some problems with my Transmission slipping and shuttering when I attempted to release the clutch and put any sort of throttle to the mix, in other words the only way I could get the car off the line in 1st gear smooth, was to really baby the clutch and throttle. And if I stopped at a stop sign or light and there was any sort of hill in front of me...forget it ! Good thing I don't live in San Francisco
Anyway inspected and had my transmission inspected, along with the CV joints by a friend of mine who ownes a couple of Porsches. He said everything looked good...I checked the Trans fluid and it looked clean...![]() I was pretty much out of ideas, I even replaced the trans mount...turns out the transmission fluid in the car was the problem, taking into consideration the car had a Jiffy Lube sticker on the window when I bought it, who knows what they changed the fluid with...? I filled the transmission as high as I could with 75w-90 Red Line and no more slipping or shuttering...amazing !!!
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
Toofah King Bad
![]() Sweet.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Used & Abused
I did that once, filling the transaxle as high as it would go, it damaged the differential seals and slung tranny fluid all over the place.
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Clarks manual recommends filling it to the top ???
Used & Abused
Yes and no?!
"pour the new transaxle fluid into hose and into the transaxle until the fluid level is just below the bottom of the fill hole (6-8 mm). Personally, I fill to the bottom of the fill hole." The factory manuals said to fill to below the bottom of the hole. I only noticed that when looking for info on replacing the diff seals. When you said "I filled the transmission as high as I could", I had a vision of the car jacked up on the left side to tilt more fluid in.
No, I guess that is what I meant, I filled it to the top of the fill hole, or as high as I could go. I did the same thing with my BMW 5 series, as I tried to put the spec amount of fluid in the car and it bucked like a Bronco (the horse that it). Then I decided I would just fill the thing as high as I could and all was fine.
Toofah King Bad
