Brake Cleaner into Throttle Body
Last Sunday, my S2 cab conked out on the autobahn. No idle, and it could only run high revs with bad misfiring. I checked out all the vacuum lines and replaced the DME relay. Still no go. Suspected a bad reference sensor.
The AAA guy came to tow it but he first decided to spray some brake cleaner into the throttle body. From previous experiences, I'd guess. Since then, the car has run fine. Even start-up and idle has improved. Weird. My question is where that crud could've been loosened. I'd like to take out the throttle body for cleaning but I'd appreciate any suggestions where I should be paying particular attention to. Sincerely, Francis
1990 S2 Cabrio |
Toofah King Bad
Clogged/sticky IAC?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
What is an IAC?
Sincerely, Francis
1990 S2 Cabrio |
