-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Dead Speedometer (http://forums.pelicanparts.com/showthread.php?t=417618)
LowTechRedneck 07-01-2008 12:18 PM
Dead Speedometer
My speedometer isn't working, and neither are the trip or regular odometers. The MPG calculator below it works, but seems to be working in a funny way, either it pegs all the way at 60 or 0, depending on wether I'm giving it throttle or not, it never picks a value inbetween.
Could these two issues be related? Where do I start testing for the problem?
I've replaced the tiny odometer gear before in a friends 944 when it's teeth stripped off due to age, but is there another thing that could cause this?
I've already checked the connection to the transmission, since I had that out of the car for a clutch job, but it seems to check out.
Car is an 86' n/a
thekidd 07-02-2008 09:23 AM
Not a big speedo tech, but ill give you some suggestions. maybee a speedo cable, check you fuses, a bad relay. Also check to see if the ground is in place, and if you are getting power to the speedo.
Where in Pentuky do you live?
LowTechRedneck 07-02-2008 11:50 AM
That would be in the State College area, dead center of the state
DSPTurtle 07-02-2008 01:08 PM
I have an 83 so it may be different... but, someone (me) might have accidentally forgotten to put the little retaining clip on the left front grease cap to hold the speedo cable in place once or twice (but who is counting).
Anyway, sounds like yours is different since you mention the trans. I just know that when I get know speedo or odometer readings at all it is because that little cable is no longer firmly attached and spinning around :)
hpservertech 07-02-2008 01:51 PM
Late cars are different then early cars. There is no speedo cable. it's all electronic.
Could be a few things.
Check all your grounds and clean any that dont look shiny
Could be the impulse sender/gear on the transmission. Easy to replace.
Could be the wire from the impulse sender to the gauge cluster
Last thing it could be is the gear
I'm betting though it's one or a combination of the first 3. For me it was the wire between the impulse sender and the cluster.
DSPTurtle 07-02-2008 02:24 PM
Dang... you guys get all the cool stuff. Electric speedos, 16 valves, turbo chargers and I bet your A/C works well too!!! I am jealous.
Is there a relay or fuse that runs that circuit?
hpservertech 07-02-2008 02:26 PM
Only fuse is for the entire instrument cluster. Wont be a fuse though since it works sometimes and sometimes it doesn't.
I wouldn't say it's cool stuff. It can be an absolute roayla PIA to track this stuff down when it's not working right. Mechanical is always better then electornic in my opnion. So much easier to troubleshoot....so that means it's cheaper to fix when it goes to the shop too.
