Jeff A.
Mystery Wires behind Radio
I'm replacing my radio tonight on my '88 944 NA project car. i pulled the original Blaupunkt radio out and found the wires I expected connected to the radio. I also found several other wires loose in the same area but not connected to anything. All the switches and equipment on the dash appear to be working so it is not obvious where they go. Could they be for powering the optional equalizer that this car did not have? Here is a picture that shows the wires in question. i just didn't want to button it all up to find I could have (or should have) reconnected these mystery wires to something!
Jeff A. '88 944 '99 Vanagon '03 Pilot |
My guess would be wires for the 10 speaker option or for the optional equlizer.
Vern |
In the Fires of Hell.....
I have those also.... They are "mystery wires" for me as well....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Could they be used for Euro spec cars? What are the two other spots for on the consol
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
Your car never had the equalizer, the connector for that is a white clip like the radio except it is a square.
Jeff A.
Thanks for the help.
I put the new(er) radio and speakers in and I'm rock'n out finally (and can hear KNBR sports talk radio with the sunroof off))! I just taped up the mystery wires and put them in a secure place under the radio. If I ever come across something that doesn't work I'll check on the mystery wires. They were almost all red and brown so I would think they were for power to some non-installed accessory. Time will tell but I think they are just spares; on to the next project!
Politically Incorrect
explosive bolts
Edek '87 924S '91 535i |
Those are only used on the James Bond edition, they are for the ejector seat button.
(Mae) Red '86 944na- gettting new paint soon. (Abby) Black '86 944na- new addition to the family. |
Maybe to operate the convertable top....if it were a convertable? Just guessing at this point.
equalizer/fader and 10 speaker option I believe.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
