shifter linkage left me stranded (x-post)
Nice night for date-nite with my wife last evening - until on a shift I noticed a little "twist" play - one or two shifts later, shifter flopped around seemingly disconnected. Coasted to the side of the road, stuck in neutral luckily. Nice night waiting for a flat bed (to tell the truth, was sort of nice...).
Car's in my garage about to go up on stands for a looksy - I searched, but found nothing good about how to diagnose and fix shifter linkage. Any one know what to look for and what to do? Cheers.
1995 993C4 guards red 1988 944S alpine white |
Where did the disconnect come from? The linkage connects to the lever by a simple e-clip and washer. Carefully remove the shifter boots and look beneath to see if it just popped off. If you had a case of the twisties, I'd expect it to be at the front where it disconencted, not back at the transmission.
![]() ![]() Images courtesy of Clarks-Garage.com Head on over to Clarks-Garage for a complete method of checking the shifter linkage. Last edited by exitwound; 07-06-2008 at 09:17 AM.. |
--yup, circlip is missing. Off to Home Depot. Looks like 3/8" will fit it. Don't know why I didn't find that Clark's page - impatient I guess...
Many thanks.
Custom User Title
I had this happen on a BMW e30 once, it was stuck in 5th gear. I left it until night to drive it the few KM's home. I gotta tell you starting from stop lights in 5th creates quite the stink and Im sure I took years off the clutch lining!
--good to go. Used a 3/8" e-clip (didn't have c-clips - I'd like to try that, might fit better...), 7/16" was too big and popped off, which didn't leave me all that comfortable with the 3/8"...
Anyway, I recommend we all carry an extra 3/8" clip next to our spare DME relays. Thanks again.
Greasy Member
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
OK - 3/8" e-clip is not right. Popped of about a week after I installed it. Happened on the way to home depot believe it or not. Was able to pull over and fix it quickly this time. While I was in there this time I found the original and it's much closer to (but not exactly) 5/16". Which works nicely so far, but I've ordered original p/n to be sure.
On the one hand, I'm pissed that the car can be disable by an e-clip failure (come on). On the other hand, it did last 20 years and 155K miles.
I put the original back on mine because it popped itself off. However, my linkage didn't disconnect from the lever. I noticed the extreme slop though and inspected it and yup, e-clip had popped off.
