tnporsche's Avatar
Ac gauges
One is comp on other is off.
Freeze 12 92 deg @ 12
' in front of coil
Air in vent 55 deg
Does this look good or does it need more F12?
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 07-17-2008, 06:20 PM
Just thinking out loud
mattdavis11's Avatar
More. Get the low side to 35-40. The 944 takes 950 grams of R12, or 2.09 lbs. Freeze 12 operates at a higher pressure, so the rule of thumb is 10% less than the rec'd for R12. That puts you at 1.88 lbs of freeze 12 for the system, but that also varies +/-. I'd put in a 1.9 lbs and then look at the gauges and a dash thermometer and dial it in. Keep an eye on the high side, if it gets to 275-300, shut it down and clean the fins on the condensor.
Clarks has the pressures at these numbers. Mine gets colder than this and the pressures are different, but I imagine this is for R12. I'm 134, it's 100 everyday and my vent temps are 37-42 at 2K- 2400 rpm, which is where you should dial it in. I also work on car a/c's everyday, so naturally mine is going to be damned cold.
90 °F ambient
35-40 psi Low
190-225 psi High
44-50 °F Vent
91 FJ80
84 Ram Charger (now gone)
Old 07-17-2008, 07:37 PM
tnporsche's Avatar
What do all the other marks mean?
Ohh Its not on my 944,
I am a true shade tree mech, also notice tree in tree(see photo)
My shed blew away in a March storm,
Lowell
Old 07-17-2008, 08:25 PM
1 bar is 14.5 psi, 2 is 29 psi, etc, but that's about as much as I know. They are just units of measurement. I see the 134 at the outer, but have no clue as to what it might mean, outside of saying what you can clearly read. To be honest, I never look at the gauges other than inHg psi. I suppose those gauges could adapt to just about anything if you had the right fittings. Your concern is the inside inHg psi #'s though. Bump it up, it's low for any car.
91 FJ80
Old 07-17-2008, 08:55 PM
Just what matt had suggested, just hit around 35 psi at 2000 rpm and wait until the radiator fans are running so you can check and make sure the high side does not go above 300 psi in stop/go traffic.
The other marks are for saturation temps of different refrigerants at saturation pressures for checking superheat and subcooling on a/c systems.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 07-18-2008, 07:20 AM
