1987 944S OPRV oil leak
Hey guys, I just replaced the rubber o-ring and the aluminum seal ring on the OPRV and it still leaks a bit of oil. The OPRV is torqued to 33ft/lbs. any ideas?
thanks! -martin |
Proprietoristicly Refined
None. I also get a drip from the oil pressure sender. I think Porsche put the belly pan on knowing this. You would think the Germans would have a better idea
.John_AZ 1988 924S + 1987 924S |
