Hi all,
I have a 87 944S and hear clicking/ticking noise come from the glove box area. Does anybody have any idea on what could be the problem? Thanks, Ngoc |
Toofah King Bad
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Nobody Special
It's probably the solenoids controlling the doors for your HVAC system. When a vac line comes loose, breaks, or leaks it can make them cycle and drive you crazy. Does it do it more when you turn on the fans, AC, or heat?
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
unindicted co-conspirator
I think that was an option for the northern irish and saudi cars
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
There is a very small fan located behind the clove box that pulls air from the cabin, it is part of the climate control. The fan has a rubber hose that attaches to the little grill next to the clock just above the glove box. Over time allot of dust collects on the fan blades and can cause a slight ticking noise. To clean the fan just remove the clove box and pull the rubber hose off. I used rubbing alcohol and a q tip.
A.J.
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
