1983 - 944 Engine question
Hi, I have a 1983 944 Euro and I have to add alot of oil.
The car smokes alot and there is oil in the air box. How would I test to precisely to know if only the cylinder head needs to be redone or the entire motor?
Note - the rod bearings have been replaced 3000 km ago.
Thanks,
Darcy
Old 08-13-2008, 07:42 PM
Professional Bull5hiter
Outback Porsche's Avatar
Could be the o-riings on the Air Oil Separator, or the AOS itself need replacing.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 08:21 PM
by the AOS..are you referring to the 2 o-rings where the oil filler neck attaches to the top rear side of the head/block?
if so, I have replaced the 2 filler neck o-rings, all the gaskets from the the cam tower upward, rod bearings and OPRV.
Old 08-13-2008, 08:39 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Look under the cap of the oil fill tube. If it's clean then I would look elseware. But if it's caked in oil then either the new o-rings aren't doing their job or the fill tube is cracked.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 08-13-2008, 08:53 PM
Yep, they are the o-rings I was referring to. I had a similar issue 6 month ago (oil in air box and smoke in engine bay). Ended up replacing the AOS - problem fixed. Also found all my vacuum hoses full of oil, hard and brittle, and replaced them at the same time.
Cheers
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 09:11 PM
The oil filler cap did at on time have a light film before I changed the 2 o-rings but was never caked in oil. Now under the cap is clean.
I don't have any smoke in the engine bay, but there is a continuous stream of black/blue smoke out the tail pipe.
Old 08-13-2008, 09:12 PM
You sure you got the rings on right? If I remember right they are different size for the top & bottom.
86 Metallic Grey
Old 08-13-2008, 09:14 PM
It depends on the engine number. Look on the PET - mine were both the same size. The engine number will also determine the part number of the AOS.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 09:17 PM
I very well could be wrong....most likely am.
86 Metallic Grey
Old 08-13-2008, 09:19 PM
I don't remember exactly because I changed the o-rings over 1 -1/2 years ago, but i did get the 2 o-rings from the Porsche dealer and recall that they went on nice and snug with a good fit of the filler neck to the block.
All the hoses and engine seems to be dry and not have any oil residue.
With this and a few other issues, I haven't driven the car since
Old 08-13-2008, 09:20 PM
It could also be time for a compression and a leakdown test.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 09:45 PM
Yes....I will do a compression test this weekend and hopefully a leakdown test too?
I will take some pics and post the results
Old 08-13-2008, 09:49 PM
There may be something a Clarks - haven't looked. Here's a faq I found on the web - looks alright.
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Cheers
Jeff
83 944 Guards Red
23 718 GT Silver
Old 08-13-2008, 10:04 PM
Back from Beyond
How are your valve stem seals? When you changed the rod bearings, you probably got better oil pressure, and if the valve seals were marginal they may have let go. And a compression/ leakdown test won't find this.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-14-2008, 11:52 AM
[QUOTE=Magnet;4119099]Yes....I will do a compression test this weekend and hopefully a leakdown test too?
These are the results of the compression test after the car was warmed up to normal operating temperature and spinning the car over 10 - 15 times....
Cylinder # 1 - 145 psi
Cylinder # 2 - 151 psi
Cylinder # 3 - 152 psi
Cylinder # 4 - 149 psi
So...what do the above compression results tell me? The compression range between the four cylinders is ~ .048 (145 * 4.8 % = 151.96)
I'm thinking that a leak down test is next? What will a leak down tell me.
Any other information is greatly appreciated,
thanks,
Darcy
Old 08-17-2008, 08:02 PM
How do I check the valve stem seals. When I changed the rod bearings, the oil pressure got better, but not by much !!!
Old 08-17-2008, 08:05 PM
Old 08-24-2008, 08:01 PM
rudidelange's Avatar
Valve stem seals may become hard after 20+ years, add to this some valve guide wear and your car might start using oil. A tell tale sign is smoke on starting, as well as smoke from the exhaust we you decelerate from high speed. Oil escapes past the valve stems into the combustion chamber - smoke and oil consumption.
The only way to rectify this is to remove the head, fit new guides and stem seals. The valves are pretty hard and could be used again. Fitting new guides will require that the seats and valves are cut to ensure proper seating.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 08-28-2008, 12:30 PM
