Cars & Coffee Killer
legion's Avatar
Clutch Pedal Travel
I haven't driven the 951 in two weeks.
Suddenly I notice that I can press the clutch pedal down about an inch before the hydraulics engage at all. Is this normal? I may just be noticing something that has always been this way.
5 liters of VVT fury now
-Chris
Old 09-15-2008, 08:09 PM
earlr85944's Avatar
sounds normal, there should be some free play, when there is no play is when there is a problem
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-15-2008, 08:34 PM
i dont have any freeplay, ive always thought you didnt want freeplay.
1987 944 n/a
Old 09-15-2008, 08:59 PM
Nobody Special
There should be about an 1/8" at the pedal. Otherwise your TOB and clutch fork are always in contact under tension.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 09-15-2008, 09:06 PM
Toofah King Bad
Rasta Monsta's Avatar
There's an adjustment in the FSM for this.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-15-2008, 10:58 PM
legion's Avatar
Fsm?
-Chris
Old 09-16-2008, 07:46 AM
Greasy Member
many944s's Avatar
Factory Service Manual
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-16-2008, 11:27 AM
legion's Avatar
Is it online?
-Chris
Old 09-16-2008, 11:54 AM
Greasy Member
many944s's Avatar
Do you still have the CD you got at the gathering?
If so, it is on there
-Nick
Old 09-16-2008, 12:30 PM
Toofah King Bad
There should be .5 mm clearance between clutch push rod and master cylinder piston. This translates into approx 3 mm play in the pedal.
Old 09-16-2008, 12:39 PM
exitwound's Avatar
There is a bolt that can be undone and the freeplay can be adjusted. If this changes, though, I'd look into the master cylinder a little deeper.
-Patrick
Black 1986 944
Old 09-16-2008, 05:27 PM
