brake/clutch bleeding
OK! I have been bleeding most of my life, but this one is kicking me. I lost pressure and looked for leaks and found none. I bled the system and continued to get air, especially at the clutch slave. I replace the clutch slave cylinder and went to bleeding again. I am still getting nowhere, but a lot of air and 3 qts. of fluid now now. at least I have clean system, but it is full of air. I have done both the pump method and the mighty mite. Is there something about a 944 I don't know here?
Barry
1987 924S 2.5L 1976 914 1985 944 Bradley GT Two 60s Mopars |
1984 porsche 944 na
Motive bleeder you need..but if you don't have one make sure the ass end of the car is higher than the front when bleeding the slave cylinder..
Custom User Title
You don't have any brakes or just no clutch? Did you keep the fluid level in the MC resevoir high enough? And still kept getting air in?
I just bled my clutch slave, and had sort of the same problem - mass air was getting in. I think what happened is that air was getting in through the threads of the bleed valve on the slave (not the brakes). I worked on it for maybe a couple hours with a Mighty-Vac and got nowhere. I broke down and got a Motive Bleeder and solved the problem in maybe 15 minutes (after pushing out what seemed like 10 gallons of air). That pressurizes the MC (rather than sucking the fluid out with a Mighty-Vac). On my 83 NA, I solved the problem differently, by bleeding the slave by loosening the hydraulic line, rather than the bleeder - which of course is strictly a no no. But it worked. The line goes in at the top of the slave which is good in terms of getting the air out. Maybe the bleeders on your brakes are leaking air like the bleeder on my slave? Overall, I like the Motive Bleeder better.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
i biult this
red neck but works great done five minutes install an bleed k u need a zip lock bag, brake fluid,a peace of 8th in vac hose bout a foot- foot an a half an some zip ties. k
now unscrew bleed screw on slave tilt 45% thin fill til fluid runs out bleed hole now master an slave are full install slave then fill bag half way with fluid then insert hose to bottom tie off an make vent for air to get out now atach other end to bleeder unscrew now top off resivor an push pedal down by hand slowly watch bubbles flow out hold for 5 count then pull back up fluid will rush in both ends repat till no air is seen close bleed screw make sure screw not to lose or will let air in while ur doin this check to see if some fluid runs down the bleed threads after the first push pull if so tightn a bit after no air is seen tightn te screw an give it a few fast pumps by foot on the last one go 75% down then come back slow wate should be done good luck works on any hydraulic clutch system Last edited by chevy/porsche g; 10-15-2008 at 03:11 AM.. |
