Sunroof cable question
Should the cable extend out like this?
If not does it just need to be adjusted or is something likely broken?
'99 996 Arctic silver over black. In the past I've owned and wrenched on a '96 Audi A4, '86 944 NA. '79 928, '72 914. Non-Teutonic vehicles of interest: 3 MGB's (one converted to V8 power), Triumph Stag & TR250, Jensen-Healey, T-Bird SC. Most recent "project" was a Factory Five MKII Roadster.
Old 10-15-2008, 07:09 PM
...Anybody...Bueller???
Old 10-16-2008, 12:50 PM
thekidd's Avatar
Send a message via AIM to thekidd
I think it is supposed to be likr that, never took a look at my 85.5 cable though? Does your sunroof not work? On the 924S and earlt 944's the bacble extended all the way out, not "U"shaped like your
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 10-16-2008, 02:35 PM
In the Fires of Hell.....
kdjones2000's Avatar
NO!
What has happened is that either the black plastic joiner connecting the motor assembly to the tube up to the gears has separated, or the white plastic arm on the motor assembly has broken.
Take things apart and it should be obvious.
To put things back, look at Clark's Garage or the shop manual. Several things to get set up correctly if you want to not strip your lifting gears.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-16-2008, 04:18 PM
Great, thank you!
Oh, that arm! Yea, I can feel a white plastic arm, it rotates independent of the wheel and - from what I can see w/o removing the motor assy. - the cable runs thing an eye on the end of it.
I'll pull it off and have a look.
Thanks again.
Old 10-16-2008, 06:34 PM
