Clutch to the floor
Went out to my car, started her, and the clutch didn't return back the the normal position. I can Pull it out by hand, but when I pres it down, it wont come back up? Any suggestions??
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
1984 porsche 944 na
Clutch slave cylinder... replace master slave and upper hose.. bleed done..
1984 porsche 944 na
If you need help pay my gas and I will come help you with my motive bleeder as well I am in NJ
I just did this to my 924S, As noted I recommend replacing the Clutch Slave, the hose and the master. I tried to get by just on a slave, Then the Hose went, then I replaced that and the master went. If you can get all 3 items def do it
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
all too common a tale
1984 porsche 944 na
I also have a brand new upper hose I bought about a month ago.
LOL, seems like its about every 3 days then this topic pops up
My friends call me, Top
it's a very common occurance with these cars . It was one of the first things I did to both of mine...when I still had two.
Matt '87 924S |
Quality
kidd!!
I have a Motive power bleeder, and my new master, slave, and hose arrived yesterday Mine did this last week! I have NOT done the replacement yet. Do you have a puddle under the car (slave), or by the clutch pedal/wet carpet (master)? All 3 = $200 from Pelican. Want to work together to replace these? Otherwise I am going to do my own slave and drive the car to RS Barn to have a friend there do the Master and hose. p3 http://forums.rennlist.com/rennforums/showthread.php?t=458927&highlight=clutch+to+floor
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
Pheonix, you say you bought all 3 for $200, is that including the powre bleeder, too?
Quality
![]() Hehe, no, it's easier to do brakes yourself. It also has the German adapter and fits well. It's still weird to use sometimes though. I really should check to make sure my friend gave it back to me!
And I too have a puddle under the starter, but dry mats!
1984 porsche 944 na
I have the Motive european bleeder as well. I still have the new upper hose as well..
