mikeran's Avatar
power steering leak
looking for suggestions, I have a power steering leak somewhere.
with power steering fluid all over the undercarriage how can I easily figure out where it's leaking?
I do know the bottom of the Reservoir is dry.
87 944 - Daily Driver - Son took it and now brought it back
Old 10-14-2008, 09:18 AM
87 944
Same problem here, when i got the car after driving it close to 100 miles home found out there was no tension on the timing belt and no power steering fluid. The leak doesn't seem to be coming from the pump. I tried some power steering fluid with anti leak but it didn't help much. Haven't been able to find the leak on my 944 because I'm in the the process of replacing belts and the water pump. Are there any ways to check if its actually the pump or the hoses?
Old 10-14-2008, 11:02 AM
Proprietoristicly Refined
John_AZ's Avatar
Step One..
Place rags or pan underneath PS boots
Step Two.
Slide PS boots off of rack side. Did a lot of fluid spill out? If yes procede.
Step Three.
Follow www.Clarks-Garage.com extremely well written chapter on PS rack replacement.
Step Four
Replace tie rod ends if rubber is cracked
John_AZ
1988 924S + 1987 9214S
Old 10-14-2008, 01:07 PM
Or, you can buy my manual rack conversion!
Sorry to steal the thread, but I just removed the manual steering rack from my 95 968, and put it up for sale...
E-mail me at flamthrowr@aol.com if interested.
Jason
Jason Judd
Old 10-14-2008, 02:05 PM
Will program for food
ghnat's Avatar
Well, I just bought all 4 power steering lines and replaced them. Cheap, no, but I do not have any leaks. They were about $450.00 in total. Plus I upgraded to hex banjo bolts for the ps rack. from what I have read this happens frequently. Someone told me that NAPA (or similar shop) can replace just the hoses. Might be $worth it...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 10-15-2008, 04:40 PM
John_AZ's Avatar
I hope you replaced the reservoir as well. The filter clogs over time and should be replaced--about $20
John_AZ
1988 924S + 1987 924S
Old 10-15-2008, 05:31 PM
ghnat's Avatar
John,
No I didn't. Another pelican purchase.... Thanks!
Greg Hnat
98 Jeep Cherokee
Old 10-16-2008, 02:39 PM
put some uv dye into the ps reservoir. i doubt it'd hurt the ps pump or rack but it'd show up clear as day where it's leaking out from
Old 10-16-2008, 02:53 PM
Dirty little kitty
PorscheKitty's Avatar
Send a message via AIM to PorscheKitty Send a message via Yahoo to PorscheKitty Send a message via Skype™ to PorscheKitty
after you clean with simple green or...brakleen you can use like a powder spray or like baby powder...if theres a leak it will absorb it and make it wet looking...helps if you don't have a uv light. I used this to find the oil leak on my friends car
Old 10-17-2008, 01:17 PM
