Heater/ A/C Blower motor
My heater will not blow any air out of the vents with the switch in any position. I have checked all the wires and get aprox 5v 9v 12v through the switch. The ground is good and I even cleaned the switch. Does the A/C use the same blower as the heater? My A/C blows air just fine.
1984 944 NA 5spd |
Redline Racer
Here's a diagram for an 84.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Back from Beyond
The resistor dries out and goes bad, but it's an easy fix. You'll have to cut the squirrel cage (fan cover) sealant to get the cover off. Also, the fan switch fails, too. You'll still get good voltage and ground, but the switch won't close the circuit for you.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Looks to me like its probably the resistor, Now how do I go about fixing it?
Edit: Its the switch, jumped the pins and fan runs at all 3 speeds.
1984 944 NA 5spd Last edited by Majin325; 10-19-2008 at 08:57 PM.. |
