speedo odo stopped, now what?
There was a recent post on this topic but it went unresolved. Now I am in the same boat. After having the car up on jacks to work on the cooling system, the speedo and odo stopped working before the next test drive. Weird coincidence?!
I have read many posts on this but none that are definitive in this situation. I believe that there is no cable involved as this is a late model (91 S2) I have replaced the sensor in the transmission I have cleaned the ground next to the sensor Can anyone answer the following? How do I test the wire, at the sensor, backwards (I have very limited electrical experience and hope this is a good place to learn some basics)? Could it be the speedometer/odometer gauge itself? If so, can this be tested and confirmed instead of buying and replacing? Could this be two problems in one? I read some posts saying it could be the infamous gear AND a speedo problem. However, since I have replaced the sensor I am hoping this is ruled out. Thanks for any help as always, |
any other guages out? check relays
No other guages out. Don't suppose there is a relay for just these two?! I will do some switching anyway just to rule it out.
It looks like I will be taking out the gauge after all. As I do this, does anyone know how I test the wiring while the gauge is out? I mean, I am sure there is a way to test resistance from the gauge back to the sensor in the transmission but which wire and how?! I have GOT to learn this electricity stuff some day!
Thanks! |
One thing you can do that will potentially rule out some causes is attach the new speed sender to a drill, then have someone up front check to see if the speedometer moves. If it does, then you are missing a little gear in the tranny. If it doesn't, you have gauge/wire problems.
What a great idea! I will do this when I am checking my CV bolts!
| All times are GMT -8. The time now is 06:48 PM. |
