Anti-lock brakes
How can I tell if I have anti-lock brakes?
I just bought the car - it's a 1988 with 17K miles on it and it's been sitting for 6 years (covered in a garage). When looking at the fuse panel, I noticed that the spot that is supposed to have a relay for anti-lock brakes is blank. Just wondering where the control unit is located and what it looks like. Thanks.................Vern |
I had this unfortunate experience and I discovered all the other abs parts absent as well. There is something like a box or a valve that is supposed to be in the passenger footwell. There should also be wheel position sensors (different than the brake pad wear sensors) visible if you take a wheel off. I can maybe get you more info later. I'd bet you don't have it if you don't have the relay though.
'74 911 Targa - Sold to the highest bidder '87 944 Turbo - Fix for track addiction '72 DeTomaso Pantera - Sold to the only real bidder |
Thanks for the info. It doesn't really matter to me ir there not there but I thought that all 1987 & later cars had them. This car also doesn't have air bags which I thought were standard on 1988's - oh well.
That Guy
Passenger side footwell, there should be a rather large box on the right side.
You can also check the option codes in the spare tire well, option 593 is ABS. You can also do about 30-40mph and jam on the brakes, thats the easy way to find out.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
I thought 87 and later had ABS and airbags as well, based on Excellence Magazine last summer which stated that they all do, not so.
My 87 has neither. I'm thinking they thought an automatic doesn't go fast enough to need either!
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Gon fix it with me hammer
my 88 has it, and it's listed as an option it wasn't default.
593 ANTIBLOCK SYSTEM (BOSCH)
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Non Compos Mentis
Re: Anti-lock brakes
Get up to high speed and slam on the brakes. If there is lots of smoke and noise, you do not have anti-lock brakes. |
Custom User Title
ABS was an option on the 88 Turbo (i thought it was standard too, till i turned on the motor of my 88 turbo and didnt see the light), but was standard on the 88 Turbo S, 89 NA and 89 S2.
Airbags were standard on the 87 and forward turbos and all S2s. |
Re: Re: Anti-lock brakes
Coming up on your left...
Flat spots on the tire FTW!!!
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
My 87 24S definitely does not have ABS. I do not personally like ABS... it just makes life more appreciable when you *don't* have it.... :-)
M |
i disconnected abs on my S completely ... unplugged the brain then connector T40 to kill the warning light...
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
Would you mind telling where it is? Thanks.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
it's a flat connector, an inch wide, should have one white wire on the end of one side, and should dangle somewhere on the top left of the passenger foot well, above the motronic brain...
Thanks.
My '88 has neither ABS nor airbags.
nate
1988 944... and a bunch of other cars
T40 connector
Is this the one Stijn? ![]()
