-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Airbag fault codes (http://forums.pelicanparts.com/showthread.php?t=444290)
ghnat 12-02-2008 06:52 PM
Airbag fault codes
I used Clarke's Garage to get my fault codes: 30 and 27
30 - Failure Warning Lamp short circuit, check control lamp??? check wiring harness
27 - Ignition Pill circuit 1 break (drivers airbag) plug to driver's airbag, check, replace...
According to Clarke, fix issue or replace control unit for both. Hmm, anyone have any thoughts? I have had the driver's airbag out and checked the connection. I could put a multi-meter to it and verify connection. If I am to check the wiring harness any suggestions where to start? Also check control lamp? help...
175mph951 12-03-2008 02:42 PM
the lamp is usually becasue the bulb burned out or the fuse to the instruments burned out cause the light to not work
ghnat 12-03-2008 02:45 PM
175,
Is the lamp the Airbag lamp? If so that is lit so I assume it is another lamp???
ghnat 12-05-2008 09:46 PM
Update,
I found one of the faults. The contact unit in the steering wheel.
http://forums.pelicanparts.com/uploa...1228541790.jpg
The yellow plug (2 male connectors) goes to the red plug (2 female connectors). Well, using my trusty Fluke multimeter I see either connector from the male side gives continuity to either on the female side. Looks like I need a new contact unit.
Any one have one for sale?
944 Ecology 12-06-2008 06:31 AM
Yep, we have those in stock. Less that half the cost at a dealer. Perfect condition, guaranteed.
Lemme know.
gb
