-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Headlight problem... (http://forums.pelicanparts.com/showthread.php?t=444957)
UconnTim97 12-06-2008 02:22 PM
Twice yesterday when I parked my car and shut off the headlights, they would both go up and down 4 or 5 times before finally staying down. There was an audible clicking from under the dash.
Any ideas what would cause this?
Thanks in advance.
John_AZ 12-06-2008 04:58 PM
Weather?
There is the headlamp motor relay sitting on the side of the headlamp motor. How does the rubber relay cover look? It sounds like the relay has moisture inside and contacts are shorting. You may just have to clean the bottom relay male pins.
GL
John_AZ
1988 924S + 1987 924S
UconnTim97 12-06-2008 07:04 PM
Thanks,
I'll take a look.
Tim:D
