trailpimp33's Avatar
944 wipers
Is it just my 83' or do these things have the slowest windshield wipers of all time?
If it is just my car, is there a fix or anyone have a suggestion.
Old 12-05-2008, 09:56 AM
In the Fires of Hell.....
kdjones2000's Avatar
Not too sure about the earlies, but mine are normal.
I would check your grounds, as that is often the problem.
Cheers,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-05-2008, 11:30 AM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
I do have problem witht the earlies 944 wipers motor I have replace with rebuild wiper motor which it is hard to find even an rebuild motor. I find it is slower then the late model.
The earlier 944 wiper motor is easier to re and re then the later model, I did try to save the motor before replacing with a rebuild but the gear was wear out badly.
Good luck
Bud
Old 12-05-2008, 11:40 AM
Cone Wobbler
curveto's Avatar
It's a Porsche thing.
If you think 944 wipers are slow drive an older Porsche. Given enough re-enforcement / time, you will come to understand that nothing made in Germany by Germans ever has any defects. Zee design ist perfect...
Drive faster and use some RainX.
Old 12-09-2008, 08:15 PM
thekidd's Avatar
Send a message via AIM to thekidd
slow here too. Dont remember my 924S wipers being like my 84 944 wipers.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 12-10-2008, 03:38 PM
One apex at a time
Dean924s's Avatar
Motor is getting old gears need lube. Also is the plastic cover in place protecting the motor form the rain snow etc? Unless it is a race car it is very important that the plastic cover be in place.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 12-10-2008, 04:31 PM
